A propos du gaz
babars06
A propos du gaz
Messagepar babars06 » 23 Sep 2007 15:06
Bonjour question afin d'etre sur!!!! Propane gpl quelles differences??? je crois que c'est identique?? merci j.L
Messagepar Serge Loriaux » 23 Sep 2007 16:37
Propane et LPG sont la même chose. LP pour Liquified Petroleum ou pétrole liquéfié. Sauf erreur.
Messagepar sdb » 24 Sep 2007 05:23
Bonjour Serge,
Désolé mais sous toute réserve je crois que c'est "low pressure gas"
Mais dites le moi si je me trompe
Sylvain
Sylvain
Messagepar Marc_du_Nord » 24 Sep 2007 06:10
Je crois que M. Loriaux a raison,
Si je me souviens bien :
En anglais, LPG pour Liquid Petroleum Gaz.
Et en français GPL pour Gaz de Pétrole Liquide.
GMC K3500 CrewCab 4X4
Bonair 27' à sellette
Messagepar Serge Loriaux » 24 Sep 2007 06:53
Je suis allé faie une petite recherche ce matin dans Google, Wikipedia:
(Wikipedia): Le sigle GPL peut désigner :
en français:
le gaz de pétrole liquéfié
en anglais:
Liquefied petroleum gas (also called LPG, LP Gas, or autogas) is a mixture of hydrocarbon gases used as a fuel in heating appliances and vehicles, and increasingly replacing chlorofluorocarbons as an aerosol propellant and a refrigerant to reduce damage to the ozone layer.
Varieties of LPG bought and sold include mixes that are primarily propane, mixes that are primarily butane, and the more common, mixes including both propane (60%) and butane (40%), depending on the season?in winter more propane, in summer more butane. Propylene and butylenes are usually also present in small concentration. A powerful odorant, ethanethiol, is added so that leaks can be detected easily. The international standard is EN 589.
LPG is manufactured during the refining of crude oil, or extracted from oil or gas streams as they emerge from the ground.
At normal temperatures and pressures, LPG will evaporate. Because of this, LPG is supplied in pressurised steel bottles. In order to allow for thermal expansion of the contained liquid, these bottles are not filled completely; typically, they are filled to between 80% and 85% of their capacity. The ratio between the volumes of the vaporised gas and the liquefied gas varies depending on composition, pressure and temperature, but is typically around 250:1. The pressure at which LPG becomes liquid, called its vapor pressure, likewise varies depending on composition and temperature; for example, it is approximately 220 kilopascals (2.2 bar) for pure butane at 20 °C (68 °F), and approximately 2.2 megapascals (22 bar) for pure propane at 55 °C (131 °F). LPG is heavier than air, and thus will flow along floors and tend to settle in low spots, such as basements. This can cause ignition or suffocation hazards if not dealt with.
Je crois qu'on a tous un peu raison, certains plus que d'autres! :)
Retourner vers Propane/BBQ
Utilisateurs parcourant actuellement ce forum : Aucun utilisateur enregistré et 64 invités
